Originally posted by cvc7chris
View Post
would i get more mileage if....
1991 Cappuccino Brown LX Coupe
2013 Rallye Red Civic EX Coupe
Originally posted by sc2dave View Postnah,the only part worthwhile that HE can take.
Go ahead. Take the ECU, the wheels, the motor... take it all. Have fun using it on the CB7.
Or you were correcting my sentence structure? I assure you... "you" wasn't directed to anyone in particular. "you" was the universal '"you" as a CB7 owner'. The 3rd gen Prelude steering wheel is the only worthwhile part for a CB7 owner to take. How's that?
Originally posted by sc2dave View Postrun rich? how, if the O2 sensor will still run the same air/fuel ratio it's programmed to run at.
I was getting about 24mpg until I had my ECU tuned. Now I get 32. That was a stock P13, which are notorious for running rich anyway (now a chipped P28).
imo and experiences an aftermarket intake will increase your mpg if you continue to drive it the same way. it has the potential for better mileage because whats its doing is really not adding more air but your lessening your pumping losses
An aftermarket intake with a stock exhaust still keeps roughly the same powerband. The exhaust (and header if you add that) usually raise the powerband a bit, making it rather soggy down low. People generally rev higher with those things.
So yes, JUST an intake can cause an increase in MPG. It also doesn't create all that much more airflow, because the engine can only take in what it can push out. You'll probably still use more fuel, but due to the higher efficiency of the intake over the stock unit, it evens out (and can even be better). I know a few people with an intake only, and they DO see an increase. I saw 1mpg on my GTP as well.
I'm seeing at least 2mpg with my DYI ram intake IN THE CITY.
Haven't even gotten a chance to drive on the highway yet, so I don't know that info.
It was worth the $26 to install it for the MPG gain90 accord EX automatic F22A4 232,500
DIY ram intake
0gauge/4gauge BIG 3
stock alt rewound to 120amps
optima orange top 830cca 1030ca
fully synthetic valvoline "Max Life" 5w30
Other rides:
2004 Jeep Liberty v6
2001 Honda civic ex coupe 1.7 vtec
