gas lite
    gas lite
    hey fam, i have a question has anyone had trouble with their gas lite on the dash not working? it's been out for 2mths. i checked the bulbs in the dash and they all work. so i have no idea what it may be. any input would greatly be appreciated.,
    Could be the fuel tank sender unit, with a bit of dirt on the bottom of the sender.
    Does the gas gauge read all the way down to empty?
    My 5.7 LS1 Holden Ute
      another issue related to the gas light.
      My gas light came on when I had the OEM 14 year old factory fuel pump, but it died and I replaced it with a cheap bosch.
      Ever since then, when my tank gets to about 1/3 its effectively "OUT OF FUEL" even though its not. I cannot get more then 13.1 gallons in it at that point and its very close to empty. So close that it will studder and sometimes fail to start. I'm guessing the new fuel pump isn't able to pull fuel out of the bottom of the tank aswell as the OEM. So for my cb7, 1/3 with no gas light = GET FUEL NOW or you will be walking.
      90 accord EX automatic F22A4 232,500
      DIY ram intake
      0gauge/4gauge BIG 3
      stock alt rewound to 120amps
      optima orange top 830cca 1030ca
      fully synthetic valvoline "Max Life" 5w30
      Other rides:
      2004 Jeep Liberty v6
      2001 Honda civic ex coupe 1.7 vtec
        Yea, could possibly be the sending unit, like stated above.
        And I have the same issue 90H has. Once my needle gets to the 1/3-1/4 tank mark, my gas light comes on. With the car completely out of gas, it'll only take 10.8 gallons. So, that's telling me that my pump isn't the pump from 1991, therefore...I know it still has life, but it's makin' my gas tank look really tiny. A unit isn't hard to replace. You can do it yourself, without droppin' the tank.
        98' Mustang 3V Swap
        11' VW CC R36
          sending unit
          yes like the other guys said it used to come on at 1/3 to 1/4. u know start to glow orange. last nite i let it get into the red and still no lite. so yes it does get to empty. and thanks for all the help. by the way does anyone know how much an oem sending unit is???
            sorry, I have to post this.
            Gary A.K.A. Carter
            [sig killed by photobucket]
              Mine was fine, I could run it till empty on the OEM pump. I replaced it with a bosch b/c it was ALOT cheaper, and now I can only run it till 1/2 of a tank or it will die.
              No worries, I just keep mine above 1/3 tank, no problems
              DIY ram intake
              0gauge/4gauge BIG 3
              Other rides:
                Gas lite. That's what Miller Lite gives me.
