window stiking, common problem?
    My power driver window goes down about a third of the way then,BRRRRRRRR! it gets stuck. If i push it down,it'll go another third then BRRRRRRRR! Is this a common problem? I've greased the rollers from the moving parts but,no dice. 92lx
    mine does that when its really hot outside or it just finished raining. I think because its off track.
      Mine did that too; I took the panel off and re-bent the track and its fine so long as I don't make it go up too fast.
        The teeth on the regulator are worn, Once they get to a certain spot they slip causing the Brrrr noise.
        Replace the regulator and it will be back to normal
        My 5.7 LS1 Holden Ute
          ^^^Listen to him, he's right.
            I replaced it with a different one and it still does the same.
              Did you check the teeth on the other regulator before you put it in, and also the motor teeth?
