my jdm H22 has a Fuel Pressure Regulator my problem is that i dont know how to wire that solenoid to the Ecu, does make a difference if i left it unwired?
H22 FPR solenoid
Are you talking about the solenoid that comes mounted on the fuel rail? The swap FAQ covers this. Everyone removes it, as it's purpose is not known and it makes no difference in performance. I ran mine just for the hell of it, but later removed it when it came time to smog, since the USDM H22's don't have it. The wire goes to A10 on the ECU if I remember correctly.Originally posted by ivanmrtzt View Postmy jdm H22 has a Fuel Pressure Regulator my problem is that i dont know how to wire that solenoid to the Ecu, does make a difference if i left it unwired?
so i should just remove it? what about the vacuum line that goes there, where i should re connect it?Originally posted by 4CYLPOWER92 View PostAre you talking about the solenoid that comes mounted on the fuel rail? The swap FAQ covers this. Everyone removes it, as it's purpose is not known and it makes no difference in performance. I ran mine just for the hell of it, but later removed it when it came time to smog, since the USDM H22's don't have it. The wire goes to A10 on the ECU if I remember correctly.
