Ok guys here's another issue: my car, at highway speeds, will slightly drift from left to right (as if a strong wind is blowing) when I am simply holding the wheel straight. This freaks me out and worries me that something is seriously wrong. Would not getting an alignment after changing my upper control arm cause/contribute to this?
Drifting Left / Right Within Lane On Highway! Scary!
i think you look at the front end again and get an alignment nowOriginally posted by BBuncky2 View PostOk guys here's another issue: my car, at highway speeds, will slightly drift from left to right (as if a strong wind is blowing) when I am simply holding the wheel straight. This freaks me out and worries me that something is seriously wrong. Would not getting an alignment after changing my upper control arm cause/contribute to this?
Seems steering problems and spark plug questions are the topics of the week.
Sounds just like the issue mine's had for well over a year now. Only things I haven't changed are the right upper control arm, the column U-joint, and the car itself
Already watching another thread on a steering issue, I'll be watching this thread, too.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
Mine has all that (except right upper joint. still tight, not spending more money chasing the problem), new steering rack with bushings, new axles, motor mounts tight, ride height set back to stock, different wheels/tires and pressure do make a small different but don't cure the problem, back end is tight, two alignments and two differtent shops checked it on multiple occasions.
Short story: I hate to see you spend money chasing a problem without troubleshooting. It was kinda nice to replace the original bushings and know things were knew, but I spent a lot of time and money.
But as bobbycos said, check the front end and get an alignment. It makes sense since you just did work that can affect the alignment. Depends how much time and money you wanna spend.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
what's your setup and repair history?Originally posted by BBuncky2 View PostOk guys here's another issue: my car, at highway speeds, will slightly drift from left to right (as if a strong wind is blowing) when I am simply holding the wheel straight. This freaks me out and worries me that something is seriously wrong. Would not getting an alignment after changing my upper control arm cause/contribute to this?
dont forget to check crossmember bolts and check them around suspension mounting points for tears.1990 accord Honda-Challenge, H22 powered
newer race video,older race videos
1991 accord parked, parts and back up shell
1993 accord acquired 6-11-16
you should be concerned, very concerned. look into it immediately.Originally posted by bobbycos View Posti think you look at the front end again and get an alignment now
from what I understand, not getting an alignment is most likely not the problem; if that were the problem you would be likely to have a consistent pull in one direction. I also don't think it's the sway bar. To me, it sounds like tie rod ends. I don't know how the ball joint would affect a drifting issue, but you just did the upper ball joint, right? So I would look at that as well, since you just did it. Also, look at the lower ball joint connection as you just undid that and refastened it.
Make sure the tires are inflated correctly.
I agree that you need to give a better history of the problem and your car so people can have more info to go on.Last edited by batever; 10-16-2008, 11:13 PM.
Originally posted by batever View Postyou should be concerned, very concerned. look into it immediately.
Ok here's the whole history (from my log) (I'm currently at 160k miles):
122732 Suspension Replaced both front sway bar links
130115 Suspension Replace right drive axle
141800 Suspension Replace left drive axle, Replace left upper ball joint
156687 Suspension Replace right front wheel bearing
157400 Suspension Replace left front wheel bearing
159000 Suspension Replaced right front upper control arm.
I had an alignment done at like 120,000 and that's it.
Looking at this, I think it's time for a fucking alignment.
like Yaw said i would at least double check that your shocks are still in good shape.
how about that upper ball joint? you just pressed one in instead of getting a new control arm on that side? I would be checking on that.Originally posted by BBuncky2 View Post
