do 97-01 non SH headers hit on a jdm h22a 92-95?
ebay h22 header
ok cool because i just bought an ebay stainless steel header and in the add it said 92-96, but the very bottom said 97-01 non sh, and it also said only usdm/edm modelsOriginally posted by tonymontana1204 View PostThey should bolt right up. The ports should be the same on all h22s. I believe the only difference in the SH model was the transmission I believe it has some kind of rear diferential or something like that..
so basically these guys are full of shit and a h22 header is a h22 header no matter what year/trim?
1991 Lx coupe........traded now I have nothing lol
the down pipe is the second peice? from where to where did you have to lengthen it, was it hard?Originally posted by Flatline View Postunless you buy one for the 97-01 models specifically. thats what i did and i had to lengthen my down pipe
yeah. its the one that bolts up to the header and has flex pipe on it.Originally posted by cleanjdm View Postthe down pipe is the second peice? from where to where did you have to lengthen it, was it hard?
i didn't take the car with me. i had to take the two pipes (old and new) and have the matched up. it wasn't easy for the guy. i also had to buy the pipe so i could be sure he wasn't ripping me off. but he got it done. wasn't exact. it was off a little but the flex pipe bent enough to catch. but i'm missing a bolt (reason for exhaust leak)
cost me $40 for the welding (originally $70/hr and it took 45 min) and $6 for the pipe used to extend it.
Just to avoid my problem, see if you can get the gaskets from honda. i think i might have blown one already and it's been 2 weeks. if it's just a generic header, that gaskets are the suck. i am going to get honda ones ASAP.
yeah, it's not the dirtiest thing either. and if you bring it to an exhaust shop it might be more though. but it'll all line up perfect. they'll cut the pipe, life the car, bolt the ends up. measure. spot weld it in place to line it up. and then finish it all up. with a lift it should be done and on in an hour.Originally posted by cleanjdm View Postok then, doenst seem too bad them, no ones gonna be lookin under my car anywayz
, and it'll jes be until i get money for a greddy one later on, on the mean time i'll have some bling under the hood. thank you for the info
