Ok i am so pissed right now! I got into a bit of a fender bender due to unexperienced drivers and the rain. Long story short I hit my front right end of the car. Headlight= destroyed, hood= dented a little, fenders fine! OK that metal bar that holds the radiator supports behind the grill is twisted a little. Can this be replaced and what is this called? my grill is destroyed and i can get a headlight grill, corner light light but I want to know if that metal bar can be replaced. Is this called a cross member? Any help would be appreciated because i dont want to go to a collision shop cuz it doesnt seem that major. Suggestions? advice? I just want to get my car back to decent condition with honda day coming up and its my daily driver. On a side note I guess this is a good time to upgrade my grill and maybe get some one peice headlights!
front end question
if you can take pics that would be better but i'm pretty sure i've heard people being able to replace the radiator support "beam".
the grill should be a dime a dozen ( not literally) at the PnPs. i know i got a spare 9091 for less than 5 bucks at a local yard which i went DIY with the mesh with later.
The piece for the radiator is called the "radiator core support" i believe. And yes it can be replaced. The cross member to my understanding is what your front motor mount sits on.Originally posted by newyorkcb7ss View PostOK that metal bar that holds the radiator supports behind the grill is twisted a little. Can this be replaced and what is this called? my grill is destroyed and i can get a headlight grill, corner light light but I want to know if that metal bar can be replaced. Is this called a cross member?
Yes, correct. I just replaced my tranny a few months back and removed both the radiator support AND that cross member in the process. Find a U-pull-it type junk yard. probobly not to expencive and very easy to remove.Originally posted by alkoholikwun View PostThe piece for the radiator is called the "radiator core support" i believe. And yes it can be replaced. The cross member to my understanding is what your front motor mount sits on.
