15 Ignition output signal does anyone know what this is??
    my car has cose 4 and code 15 4 being crank position sensor and 15 being Ignition output signal. anyone have any ideas??
    When I had the "ignition output signal" problem, we replaced a white box inside the steering wheel shroud.
    Just take off the plastic behind the wheel, and look at the bottom, you'll see the white box.
    That's what fixed mine.
      I believe thats often the ignitor and with the crankshaft position sensor, sounds like you need a new distributor
        I replaced the ignitor when I got that code, and that fixed it. Stupid vague codes...
          Could be also the ignition coil , I got code 15 when I forgot to connect my ignition coil. An electrical tester would be helpful at this time to determine if it's the coil or ignitor like Deev said.
          Code 4 Crank sensor is inside the distributor , I doubt you'll get a replacement part for that as brand new. Only way to replace that is either yank a sensor off a yard or get a distributor brand new.
          1996 Honda Civic LX 2009-2012
          2012 Kia Optima LX 2012-2013
            Oh yeah, I replaced my coil as well (that was acutally the cause of my no-start problem... )
              With that being said , I'm going to replace mine since it's 189,000 miles old.
                I got mine from the junkyard. $5 coil FTW Igniters were free.
                  Arr mine is $5 more.
                  From ebay.. Niehoff $100 I won it totaling $9 with shipping lol
                    You may have a dizzy wiring problem if you're getting 2 codes that could be coming from parts inside it. Definitely Ignitor or coil with that code. You can check resistance on the coil, autozone can check an ignitor chip if you can find someone there who knows how to read or use the machine.
                    PM me and get it done right!
