As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
some issuesss
    Originally posted by 91project View Post
    is there any instructions anywhere on how to bleed it because i know exactly where the screw is i just dont know when to tighten it after i loosen it. is it untill i get a steady flow of coolant comming out?
    Yep, untill the bubble have gone and it's a steady flow.
    Note you will have top keep topping up the radiator as the collant level will drop as you let the air/coolant out.
    My 5.7 LS1 Holden Ute
      ok so can i just add fluid in the rad after i get a steady flow or should i do it while im waitin for the steady flow
