As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
calipers?
    calipers?
    i have a hole in my brake caliper and need to replace it asap its leaking brake fluid and wanted to know a good performance brand or should i just go for an oem replacement
    It'd be pretty hard to punch a hole in your caliper, even using a hammer.
    I suspect either the bleed nipple has somehow come off, or the piston seals are leaking.
    Have you got a picture of the hole in the caliper?
    Presonally I would just get a junkyard OEM one, unless you plan on some serious hp later on.
    If so then I would do the ROH conversion at the same time as new calipers
    My 5.7 LS1 Holden Ute
      thanks i dont ill take some and post them later on today
        Just get NEW oem ones and u will be good, anythin else is gona cost u an arm and leg.......
        VTEC DUDE!!!!!!!
          x2....
