Can I fill my tranny through the reverse light sensor hole?
Filling Tranny?
Filling Tranny?
_UNDER HEAVY CONSTRUCTION_
My Precious Toy
Swap Thread
916 Cb7
"92Ex KT"My New Addition[W.I.P]
"93Dx KT"SOLDTags: None
I would venture a guess and say no. But is it an auto or manual?
Auto would be filled through the dipstick tube...
Manual through the filler bolt.Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
If this is a manual you can also remove the rubber breather tube cover and fill the tranny through there with a small funnel. However, you'll still have to remove the filler bolt, not only to see when you've filled it enough, but also for the tranny to breath as you fill it. Most importently, make sure the car is level when you fill it.
Just to specify, this is NOT referring to the rubber stopper covering the hole used for setting your ignition timing!Originally posted by pwrusr View PostIf this is a manual you can also remove the rubber breather tube cover and fill the tranny through there with a small funnel. However, you'll still have to remove the filler bolt, not only to see when you've filled it enough, but also for the tranny to breath as you fill it. Most importently, make sure the car is level when you fill it.
^^ X2 it will just take longer than through the main filler hole, due to the size of the hole
OP yes you can fill through the reverse switch hole, but as above, you still need to take the filler plug out to get the correct filling level.
My 5.7 LS1 Holden Ute
As I said in post three... all you'd have to do to vent the case and make sure the level is right (when the fluid starts to over fill it's full).Originally posted by Granite CB7 View Post^suddenly the rear main seal started leaking and the clutch slips! LOL
You can technically fill the manual trans. via the vent pipe, but then you'd need to vent the case (maybe unbolt the reverse sensor?) then you'd want to check the level too of course!
THat's the way I've always done it in the past on my CB and have never had any issues.
Doesn't take that much longer to fill via the vent hole.Originally posted by evil_demon_01 View Post^^ X2 it will just take longer than through the main filler hole, due to the size of the hole
