weird problem..today
    i was driving for 30-45 mins then notice the temperature gauge go normal (half way) if i accelerate and if i stop it goes up 1/4 from the normal point toward the H (3/4).
    it scared the shit out of me especially during off work times (traffic)
    whats the problem now?
    thermostat? clogged coolant passages or lines?
      idk. weird shit happens with that gauge though.
      I stopped at a 7-11 to get a quick drink, left it running. When i got out, the gauge was pinned up. I freaked and shut the car off. after a few minutes letting the fans run, the gauge was back to normal.
      i started the car, and it was fine. drove home. to work the next day. No problem. Never happened again.
      could be air in your lines. tripping the coolant temp sensor and making it tweak out
        get a shop to sniff your rad. a exaust gas analyser will let you know if you have some head gasket issuses. if there is no exaust gasses( hydrocarbons) in the coolant hopefully it's just a thermostat or low or something
        96 Accord SiR driveline installed. CF2 donar
          check the thermostat or temperature sensor
          ホンダ アコード・ワゴン CE1
          My eBay Items
          Traveling? BOOK HERE!!
            Are the fans coming on? if there's no air flowing through there's going to be an effect on the rad. It's happening to me right now, I just try to keep moving and shut the car off in heavy traffic.
              another thing to remember is that if this is the only time that's ever happened, it could just have been a fluke. i've had a car do that once, and then it never did it again and i never had a problem with it. now if it does it on your next drive too...
              basically if it's not going 4/4, it happens sometimes.
              96 mx-6, needs work...
              91 accord lx sedan, needs work...
                If u see the temp go to red, especially if u go to a store come out and its allready up there imediately shutting it down is not the best solution as coolant will boil if the engine is shut down. If u see it getting hot, rev to around 2 grand or so and let the water pump work. If that doesn't bring it down then the thermostat is either stuck shut or u have a head gasket or water pump issue.
                GOT F?
