I took off the distributor yesterday day to replace it since my car is not firing up, and this milky brown liquid poured out where the end of the distributor sticks in the engine what would that be? and is that what could be causing my car not to start?
Distributor problems
HaHa..I got the same problem no spark now....
I took my Distributor off and cleaned it up and changed the O-ring...when I got everything back together I went to start it and no I got NO SPARK...
I do belive once oil gets in it replace it.....
1990 Accord LX Sedan~Sold
1993 Accord EX Sedan~Sold
1995 Suzuki GSX-R 750~Totaled
Take the oil cap off.Originally posted by DsMJUNKY54 View PostI took off the distributor yesterday day to replace it since my car is not firing up, and this milky brown liquid poured out where the end of the distributor sticks in the engine what would that be? and is that what could be causing my car not to start?
Check to see if you have that 'milky brown liquid' in there.
Also check your coolant.
See if its the same color.
Cause if it is, your headgasket just went.
Check your radiator coolant.Originally posted by DsMJUNKY54 View PostDang man thanks so much, i think you just found the problem why my car wont start.
If it looks brownish and foamy, that usually means there's oil in your cooling system.
Which is another sign of a headgasket issue.
If you're unsure its best to have it looked at.
Oil in distributor will kill the internal distributor circuitry since once hot oil gets in there , it will be fatal for the circuits.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
It's very unlikely for new distributors to get oil in them.
I would go for Jak's comment about low compression engine since you stated oil being milky.
