ok if a engine swap is present in a car what are things that are going to change if parts are needed to be ordered for example does the clutch have to be from prelude if u got a h22a in ur cb7?? im a noob at this so excuse me if i sound retarded
changes??
lol you dont sound retarded and you are posting in the right section. This Sticky should be a good read for you.
http://www.cb7tuner.com/vbb/showthread.php?t=5423
1992 Honda Accord Coupe LX
pritty much everything from a prelude will fit... but theres a few things you need to figure out first,
what year moter, and trans and what your puting it in.
i had bought my h22a (94) b4 i had even had my car.. it was 2 be 5 speed...
bought a 91 lx wagon 5spd... everything is just about the same...
axels and half shaft are the same, moter mounts except for the tranny mount are all the same.
so in a nut shell.. wire the harness first, (get your self the service manual for both cars) you have 2 add 4 wires for the vtec. and change the computer.
you will need to leghthn a few ends... as the head is larger on the h22 compaied to the f22
Im runing lude axels in my accord right now... the half shaft very's from witch axles you want to the run... the half shaft will be ither male or female,
the engine ignition, will all be lude conected to the harrness of the accord.
when i got my engine it was complted engine and trans, partial wire harness. and Ecu
its not that hard... its really eazy if you have all your info right.. b4 you start.
almost forgot... JDm and Usdm... had diffrent coil setups. or something like that... i found out after i had got it all together...
i still dont know what the bottem line is, bot some of the accords and some of the ludes had internals coils. and others had external coil..
not that hard to fix.. i tried, both setups.91 wagon,
94 h22a
Tokico's white FULL's
Brembo Cross drilled fronts
UR Ultra R pully (1lb)
UR untra L flywheel (10lb)
nology wires, Msd Coil external wired mod
Apexi V AFC
Nice cold AC (reinstalled after 3 years)
SHaved clean, one peace perjector lights.
234000+
still rocking it
