Thermostat help
    Thermostat help
    I'm looking for a thermostat replacement DIY, is there one. I tried looking.
    A jack of all trades.. An ace of none.
    There are two kinds of people in this world... H22 swappers and F22 builders
    im also looking to replace mine too. Anyone feeling nice enough to tell us newbies?
      Follow the lower radiator hose to the engine block. It's on the side near the back, kindabelow the intake manifold. The intake will need to be removed for easy access, and I removed my distributor. Just make sure you make alignment marks on the distributor so It goes back where it was easy.
      Two bolts hold the thermostat housing on, and you might have to unplug and remove the coolant temp sensor to get to one of the bolts, I can't remember.
      It's basically a process of removing items so you can remove 2 bolts and replace the thermostat.
      MRT(vvv) --Stock CB7 Enthusiast #1--
      Vouches: new_beginnings, ThrakBarts, beanzfynest617, JaK FRoSTWhiTE, 92_EX_Ninja, mak
      i am with the dumb. i cannot brain.
        Just don't over tighten the bolts, don't wanna break anything
          Why in the world would you take the dizzy off?
          All you have to do is take off the intake tube and take out the two bolts.
          wat?
            make sure to get the new ruber seal for it to. or you may have to take off again
            h23a3 lxinks
              x2 on replacing the seal. Mine fell off and I didn't notice. It wasn't a good thing.
              ~Built not Bought~
              --member ride page--
              http://www.cb7tuner.com/vbb/showthread.php?t=130234
                Awesome, well I'll get right on this as soon as the 3 feet of snow in Spokane goes away.
                  Because my coolant temp sensor was replaced too, and I removed and installed it with the thermostat housing in place, so I'd have more leverage on it. I like having enough room to easily work tools around, so I removed the dizzy, it's only 3 bolts.
                    Some suggestions:
                    1) Might as well change the coolant
                    2) If u gonna mix, use Distilled water.
                    3) let the air out after u flush the radiator, theres a relieve bolt next to where u change the thermostat near the tranny.
