I'm looking for a thermostat replacement DIY, is there one. I tried looking.
Thermostat help
Follow the lower radiator hose to the engine block. It's on the side near the back, kindabelow the intake manifold. The intake will need to be removed for easy access, and I removed my distributor. Just make sure you make alignment marks on the distributor so It goes back where it was easy.
Two bolts hold the thermostat housing on, and you might have to unplug and remove the coolant temp sensor to get to one of the bolts, I can't remember.
It's basically a process of removing items so you can remove 2 bolts and replace the thermostat.
Why in the world would you take the dizzy off?Originally posted by 93accordfreak View PostFollow the lower radiator hose to the engine block. It's on the side near the back, kindabelow the intake manifold. The intake will need to be removed for easy access, and I removed my distributor. Just make sure you make alignment marks on the distributor so It goes back where it was easy.
All you have to do is take off the intake tube and take out the two bolts.wat?
Because my coolant temp sensor was replaced too, and I removed and installed it with the thermostat housing in place, so I'd have more leverage on it. I like having enough room to easily work tools around, so I removed the dizzy, it's only 3 bolts.Originally posted by C91BLX7 View PostWhy in the world would you take the dizzy off?
