whining noise?
    whining noise?
    just wondering if anyone has had a whining noise as the rpm's climb coming from the engine...i was told it was the timing belt since it was new that was too tight but anyhow...sounds like a supercharger to me lmao
    it can be the input shaft bearing going out........
      could be anything from the power steering pump to the alternator to the tranny going bad to any number of bearings.
      I had the same problem and it was the PS pump. was told to take a long screw driver and put the tip anywhere on the pump and put my ear to the handle.
      you can hear the internals working through vibrations. get a really long one for the alt. and check them both.
      and does it do it when your IN gear or all the time?
      but if you hear a whine from either the alt or the PS pump, remove the belt and start it. it'll run for a few minutes with just the battery. if the whining goes away after you remove a belt, there is your problem.
        I just got my car back 2day cuzz my alternator blew I thought my belt it was to tight and nope alternator was bad.. so check that also ur power steering and check ur belts too
          alright will do im about to just yank the damn power steering out anyways so hope fully i figure it out....thanks y'all
            Whining noises are often times typical shortly after a new timing belt is installed... sounds like you have a supercharger when accelerating. I'm not quite sure why this is, tension on the bearings from a new belt? Anyway, it should go away within a few thousand miles of having the belt changed. How long ago was the t-belt replaced?
            My 96 Accord had the same whine after both timing belt replacements and now my 93 sounds supercharged after I just had the belt replaced today. If it doesn't quiet back down to normal within a few thousand miles, I'll have it checked out... as you should too. Please keep us posted.
            1990 Honda Accord LX coupe
            F22
            116,xxx miles
            1989 Honda Accord LX sedan
            A20
            177,xxx miles
            1992 Cadillac Allante
            4.5L V8
            70,xxx miles
              it was changed about 250 miles ago...there's some hope then thanks dude
                Its your BLOWER MAN! :P
                jk bro.
                  dam hxc i thought you had the new jrsc for this shit
                    i just replaced the timing belt tensioner (i bitch) and now my car does the same thing. Probly over tightened. Should be allright. PEACE
                    MY MEMBERS RIDE THREAD
                      my car has the same whining noise
                      it gets annoying because i can really hear it while driving slow
                      PSN: DJ-dlatino
                      My ride
                      http://www.cb7tuner.com/vbb/showthread.php?t=140370
                        yeah i know even when going slow you hear it....lmao i'm running 12 lbs. how bout you?!
                          Since I replaced my T belt I've had a whine that can be heard between approximately 1500rpm to 2000rpm, but is slowly becoming less.
                          I suspect it's because the teeth on the timing sprockets are old and worn, i.e. the corners of the teeth are no longer crisp as they would have been when new, and the old timing belt teeth are worn into this chraracteristic of the sprocket teeth and thus run quietly.
                          When we fit a new belt it has nice new sharply defined teeth that don't quite match the worn teeth on the old timing sprockets, and as a result the teeth make some noise as the belt and sprocket move into mesh as they rotate. Over time the teeth on the new belt round off slightly on the corners, and the belt quites down.
                          I don't know how correct this is, but it's a theory. I know gears make a lot of noise if they don't match each other perfectly, I once did an emergency gearbox rebuild making one gearbox out of two, which meant running old gears in mesh with other old gears from the other box, the gears not being run-in from new to that particular other gear. Sounded a bit like straight cut gears....
                          Regards from Oz,
                          John.
