id'ing O2 sensor wiring....
    i'm installing a universal o2 sensor and need to know which wire is which for a 92 lx
    http://www.boschautoparts.com/NR/rdo...orInstall.pdf/
    scroll down to the bottom of the PDF and its there, we have a type C wire diagram. black is heater wires on the uni, white on stock harness, singal wire is white on uni, black on stock harness, and finally gray to gray.
    If you want this to work get a soder gun from radio shack for 20 buck and some silver soder. dont be stingy, and tap the sodered connects up real good with wire tape.
    _____________________________
    91 Accord F22B
      A soldering gun will not melt silver solder. Silver solder is considered a hard solder and contains a high percentage of actual silver and is used to braze metals together using an oxy/acetylene or oxy/propane torch. The OP will want to get normal electrical solder. He also needs to make sure he doesn't get acid core, although resin core is fine.
      And those universal O2 sensors are supposed to suck in our cars. The best thing is the OEM sensor.
        these are the wires i have;from harness grn,wht, 2 blks ---from o2 sensor i have blk,gry, 2 whts.which goes which?
