so sometimes my car wont start up or when i start it up it jus dies as soon as i put it in gear. so i let it sit for a second an then it starts right up. can any one answer my question? or give me some ideas of what it could be?
dying problem?
so u think i should replace my battary or should i test it first to see if its giving out full 12 volts?Originally posted by 4GFalken20 View Postill give my 2 sense. but i cant guarentee its correctness.
the battery.
simple 6 cell battery but it seems as if it may have a cell going bad in it.
and when you put it in gear it maybe drawing too much drop in voltage from your battery to cause it to stall out.
like i said i may be wrong.
it cranks but wont start so i take my key out completely an then i let it sit for a second an then try startin it again an it starts right up.Originally posted by blk91coupe View PostWhen it doesn't start does it crank over or does it do nothing? If it cranks but won't start and then dies when it does start it could be the main relay.
i dont think it has 2 do wit the battery, cuz once u turn on the car u can remove the battery an drive it n nothing happens, all it happens u juss get a lil idle problem, so it could b mayb the main relay. dont kno thoughtAT WEST COAST MEET
cb7rush: who has the tongs?JDMxDB8: i got a thong on...
to get to see more of my cb click the link below.
http://www.cb7tuner.com/vbb/showthread.php?t=130922
I would try the main relay if I were you, it is supposed to be pretty easy to fix. I haven't done it myself but I have been told you just need to take it out and have it soldered or replace it. Here is a link on how to repair the relay. http://www.cb7tuner.com/vbb/showthread.php?t=53888
[/url]
aye that was the problem. but damn if you got big hands the main relay is a bitch to get to but i saldered it an it starts right up wit no problem now. thnks for the helpOriginally posted by blk91coupe View PostI would try the main relay if I were you, it is supposed to be pretty easy to fix. I haven't done it myself but I have been told you just need to take it out and have it soldered or replace it. Here is a link on how to repair the relay. http://www.cb7tuner.com/vbb/showthread.php?t=53888
thnks for the help but i had to do the main relay instead cuz my car wouldnt start at all today after i got to my class. so it turned out to be the main relayOriginally posted by 4GFalken20 View Postyea test the battery just in case.
if you got the full 12 volts then your all good on the battery
