im having some trouble with my fans. i swapped out my front motor mount(torque strut mount, dog bone) yeasterday and after that i tried putting on my a/c fan(i was missing it and was just running with the rad fan in my car). on an auto there is a trans line that bolts in place with the lower screws that go on the fans bolt in. i tried bolting it on and it started leaking trans oil. (quick fix the hose was old and dried out and cracked) fixed that today. theni went ahead and placed in the a/c fan. i had it laying around it was new and i had tested it before and it is good, it turns on the motor on it is good. now i ran it for like 20 min and neither the rad fan or the a/c fan came on. before my rad fan would come on after a while, it never over heated, now neither of them turn on. it still doesnt overhead, i dont even see smoke or anything. i ran it a good while to school and back, about or close to 45 min-1hr and nothing. no overheating. ima try bridging the therm switch tomorrow see if they turn on already checked the fuses and both are good. my heater is working too good it blows hot air like crazy. but when i turn on the ac the fan wont kick in. only other thing i can think of besides the therm switch would be the relays but i have no idea how to check those any help is much apreciated thanks.
fan trouble
I just took the fan relay fuse, and swapped it with the power windows fuse. (if you have them). It worked my windows, so it definitely worked. I just hooked my fans to a toggle.
Saves the trouble. But, some people are pressed on getting them to work the right way, which couldn't be hard to figure out.
98' Mustang 3V Swap
11' VW CC R36
Did you swap the therm and coolant temp switch's back? Good to see you got it sortedOriginally posted by mik09 View Postit was quick fix i swapped the therm and the coolant temp sens but it ened up being the rad fan switch thanks, you can close this thread now please
My 5.7 LS1 Holden Ute
