I have a 92 accord with the f22a1 and i was wondering how to go about cleaning out the egr valve and ports any suggestions on products to use? and how to actually do the work ?
EGR valves and ports ???
Well you can actually start by searching.Originally posted by 92HndaCb7 View PostI have a 92 accord with the f22a1 and i was wondering how to go about cleaning out the egr valve and ports any suggestions on products to use? and how to actually do the work ?
You actually got this far (Knowing that you actually have to clean your EGR ports)
Here's a great link for you.
http://www.cb7tuner.com/vbb/showthread.php?t=2495
This is what i used...
I scraped the carbon off with an angled small skinny Allen wrench and Carb cleaner.
http://www.cd5tuner.com/vbb/showthread.php?t=3113
this is my personal DIY i made... if you have any questions don't hesitate to PM me or rich
I recently cleaned my EGR and port but couldn't get the replacement plugs to fit with the 'dome' up. I was ruining my port by doing it this way. I even tried sanding down the edges so it would slip in easier. What I eventually did is put the plug in 'dome' firstm don't know if its the wrong or right way, but that's how I did it
So will this solve a lopey idle cause ive change everything else on my car and i even updated my distributor to a 95 cause i liked the small screw in the rotor.
Ive had the problem since i bought the car last year and have replaced just about everything i can think of.
Replaced so far:
Fuel filter
Fuel Pump
Fuel Injectors
All vac hoses
Also have a CAI from a 94-97 accord thats made for a car without ABS even tho my car has it lol.
would a blown water pump cause the idle to lope cause that just blew on me the other day when i was runnin my car for the second time this winter.1992 Honda Accord 4 door 5spd *Sold 5/9/09*
No this will not fix your loopy idle.Originally posted by sukkafree63 View PostSo will this solve a lopey idle cause ive change everything else on my car and i even updated my distributor to a 95 cause i liked the small screw in the rotor.
Replaced so far:
Fuel filter
Fuel Pump
Fuel Injectors
All vac hoses
Have you tried cleaning your IAC?
Also, are you leaking coolant from your water pump weep hole?
As far as i can tell my IAC is fine cause i did what everyone else on here does and pulled the cover off to tighten the white thing inside and mine was hella loose.Originally posted by JaK FRoSTWhiTE View PostNo this will not fix your loopy idle.
As for my water pump im not sure if its leakin from the weep hole cause when i start the car it doesnt leak but when i shut it off it pissed like a race horse.1992 Honda Accord 4 door 5spd *Sold 5/9/09*
Im sorry but that was not the IAC you messed around with.Originally posted by sukkafree63 View PostAs far as i can tell my IAC is fine cause i did what everyone else on here does and pulled the cover off to tighten the white thing inside and mine was hella loose.
The IAC is right infront of the intake manifold with a connector going to it.
Two 12mm.
Low coolant can cause a loopy idle.
Would cause your RPM to fluctuate
Yeah i would look into replacing that water pump.
lol the water pump is kinda obvious cause i have coolant on the ground after i shut the car off...as for the IAC i did clead the part with the white ring in it but never got a chance to do the other part due to the lack of daylight and cold weather outside....also cleaned my egr valve which was a pain to get off lol. Should be getting to the other half of the IAC tomorrow sometime.Originally posted by JaK FRoSTWhiTE View PostIm sorry but that was not the IAC you messed around with.
Two 12mm.
Yeah i would look into replacing that water pump.1992 Honda Accord 4 door 5spd *Sold 5/9/09*
I think you are getting your IACV mixed up with your FITV. The IACV has a electrical connector on it and when you take it off it has a screen. Clean the screen.Originally posted by sukkafree63 View Postlol the water pump is kinda obvious cause i have coolant on the ground after i shut the car off...as for the IAC i did clead the part with the white ring in it but never got a chance to do the other part due to the lack of daylight and cold weather outside....also cleaned my egr valve which was a pain to get off lol. Should be getting to the other half of the IAC tomorrow sometime.
Yea that makes sense lol. Like i said before im new to hondas so being parts aware for me is kinda hard still.Originally posted by AbsurdNY View PostI think you are getting your IACV mixed up with your FITV. The IACV has a electrical connector on it and when you take it off it has a screen. Clean the screen.1992 Honda Accord 4 door 5spd *Sold 5/9/09*
What is the purpose of the sliding hammner?
Could I drill a small hole in the plug, the put a long pointy screw on to get some thread on it to grip the plug and pull it out? How hard is it to pull the plugs off?
Once done cleaning, just put the plugs back in.
Could this method works? If I use a screw would I push the plugs all the way through inside if it is forced while screwing on?
Thanks,
^I can't remember if mine is a 1lb or a 2, but it took me some pretty good effort to yank those plugs out. I would imagine it would be possible to get them out by other means, but IMO, slide hammer would work the best b/c of its upward impacting force. Impact is the key, not so much constant upward pulling. It would be a good idea to tap them down slightly to shock them loose first before doing anything else. I don't quite follow the last sentence but my only other idea is a really long screw that would go down to the bottom of the runner, stop, then ramp the plug out b/c the screw can go no further (and that's if the brass holds the threads and doesn't strip out). I just hate the thought of metal chips and shavings getting into the motor though, that's why I modded a whole spare IM.
