changing water pump and belts, what all do i need ??
    The water pump on the girls car took a dive, so i figure ill r&r everything i can, i know i need a new pump, timing and tension belts, cam and crank seals, pump and valve cover gaskets.. what else do i need?? do i need to replace the tensioners ?? what else is there. i want to get everything i need so i dont have to make a second trip to the store.. thanks in advance..
    http://www.cb7tuner.com/vbb/showthread.php?t=55332
    This link breaks it down for you.
      -Valve cover gasket
      -A/c belt
      -P/s belt
      -Cam seal
      -Balancer shaft seal
      -Water pump
      -Timing belt
      -Balancer belt
      Have fun...
        Originally posted by JaK FRoSTWhiTE View Post
        -Valve cover gasket
        -A/c belt
        -P/s belt
        -Cam seal
        -Water pump
        -Timing belt
        -Balancer belt
        Have fun...
        + Balancer shaft seal retainer if not installed yet...
          great link but it really doesnt list the parts needed
            to replace the W/P do you remove the motor. i mean i saw where is said let it down but i was jw if you actually have to move it alot or not? or if ill need a motor lift to make it easier maybe?
            Accord SE
            93se
            Members Ride
            Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
            Sold to: sulimed, BurtonRiderT6, tishock
              You can leave the motor in the car, the only thing you have to do is remove the driver side motor mount. When i did mine, I probably moved it up and down a couple times just to get to certain bolts, but it wasn't too bad. I don't think it's worth taking out the entire motor
              [IMG]http://i166.photobucket.com/albums/u105/akona21/cb2-2.jpg[/IMG
                lol. alright sounds good. thanks.
                man this is gonna suck to do! but no money means gotta do it my self. lol.
                Accord SE
                93se
                Members Ride
