Car shaking while turning
    Well, I'm not exactly sure what the problem is on my car but yesterday I turned the corner a bit fast after completely stopping and when i pressed on the gas my entire car starting vibrating/shaking but it wasn't stuck or anything..I'm clueless. Anybody might know what the problem is? I think it might be cause my front right shock or balljoint is blown. I'm still new so please don't be so harsh
    http://www.cb7tuner.com/vbb/showthread.php?t=119467
    Where in NorCal?
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      Originally posted by Konigstiger View Post
      Uhh, thanks dude I think that sorta helped. But I live near Walnut Creek
        check to see that all you lug nuts are tight...but if not dat den it is ur lower balls joints..happenin to me right now 2..
          i would say ball joint too.. mine was bad on the last cb and that thing shook real bad til i got em fixed..
            Yeah i would have to say ball joints or tie rods if its only under turns.
            2008 3.5SE Altima
            1992 EX Coupe-FAIL
              I have the same problem as you do, everytime I turn the steering wheel the whole car vibrates. Some of my friends said my motor mount has problem, but never exactly sure.
                well it's not everytime i turn the steering wheel for me just everytime i turn the corner going right is when the whole car vibrates..its an on and off thing since this just started happening
                  Oh I see, is your steering wheel balance? Mine isn't balance, its a bit off. Everytime I let go of my steering wheels, the car turn automatic to the side =/
                    Well, I believe it is and when it does lean to the right I just check the tire pressure ..so nope not here
                      Then you must know yaboi_jeff.
                        Yup, just saw him today on my way home today too
                          If steering wheels is not balance, is it possible to get it balance out again? or do I have to change anything?
