so I was at my local junkyard today looking for an interior door handle (of course nothing for a coupe) and noticed a cb7 with rear discs that look minty. I was wondering is worth my time to pull em off and do a rear disc convo on mine. What do you guys think.
Rear Disc Conversion
Thanks for the clarification, and good information!Originally posted by JaK FRoSTWhiTE View PostI wouldnt get the Master Cylinder.
The CB's with rear discs have larger brake line fittings that go to the master cylinder.
CBs with rear disc brakes also have ABS, which you won't be adding to your car...
The 40/40 prop valve that Jak Frostwhite mentioned is the way to go.
JONESER, if you didn't use a prop valve, then it is NOT working perfectly. You probably notice a significant difference because your rear brakes are grabbing more than they should. That can be very dangerous, causing you to spin out on wet roads, or lose control in a panic stop. Do it right. For your own sake, and the sake of anyone in your path if you lose control.
ok i just wanna make sure i can b slow @ times lol...
so from the car "with the rear disks" i'll just need both control arms & the e-brake cable?
is tht it or is there more?2004 Accord Sedan CM6 (daily)
Koni Yellows, Hood Bra,Splash Guards,Deck Lid,Weather Mats,Sunroof Visor,Fog Lights <-All OEM, Mugen Door Visors, 07 Tsx Wheels.
1990 Accord Coupe CB7 (project)
H22 Swap, Skunk2 Springs on Koni Str.t, Rear Disk Swap, Fog Lights, 92-93 Trunk Conversion, 02 Accord Rims
