Highway: Unstable Steering Wheel.. ??
    I know that if you go over 60mph the steering wheel will shake if the tires arent balanced..
    What if it still shakes after the tires have already been balanced? What could it be?
    Have you tried tightening the bolts/screws that hold the steering wheel in place ? It could be that its just loose and needs tightening
    Check Out My Work In Progess . . . . .
      could be your tire rods
        it happens only when im drivin fast..doesnt happen much when im increasing speed..but when i stay at a certain speed limit then i start to feel it shake
          No, and the steering wheel isn't held on by bolts/screws anyway.
          Check your balljoints.
          wat?
            you think it has to do anything with the lower ball joints, sway bar end links, or the control arms?
              Any or, all of them.
              wat?
                which one do you think has the higher vote..i dont want to pay for one and not have that fix the problem..
                  Thats why you check them.
                  wat?
                    yea mine did that till it got really bad and the i change out the whole upper control arm and it went away but mine did it when i would slow down....just look for small breaks in the ball joint it easy to spot
                      Might not neccessarily be unbalanced tires.. could be bad or dryrotted tires.
                      -Will
                        Ball joints and tie rods should be your culprit.
                          mine used to do this when accelerating onto the highway. It was my D/S axle that was worn out. So if you're axles are original, then its prob. that. Jack your car up and tug back and forth on your axles, if they have slop, then the CV joints are prob. worn.
                            If you have aftermarket rims they may need hub centric adapters. In town my would ride fine, out on the highway (75 mph) they would create vibration. Had the wheels balanced and no difference. Ordered hub centric adapters. Mine cb9 rim ID 73.1 honda hub 64.15mm.
                              How many miles do you have? I had 185K on my wagon and I needed front wheel bearings, upper and lower ballin joints, and tie rods. It could be any or all of those. The whole car and steering wheel would shake after 60 mph. Now I have no shaking at all.
                              1992 Accord Wagon (RETIRED)
