my 90ex i just bought has 245k on it. Im confident its still strong although it does have a light tapping sound from engine. It did pass smog and has no leaks( that i have seen). there is old oil around under the distributor. perhaps dizzy seal or something? Anyways, what do you all suggest i perform to the car to help it out like seals or something
what to do @ 245k
what to do @ 245k
We had two bags of grass, seventy-five pellets of mescaline, five sheets of high-powered blotter acid, a saltshaker half-full of cocaine, and a whole galaxy of multi-colored uppers, downers, screamers, laughers... Also, a quart of tequila, a quart of rum, a case of beer, a pint of raw ether, and two dozen amyls.Tags: None
replace the seals? the dizzy o ring is prob. shot. thats an easy fix. take dizzy off and remove petrified o ring and slide new one on. Idk 245K is high mileage regardless if the car was taken care of or not. Might need a rebuild soon, since it is kinda high. Unless you have meticulous records, I would just make sure the basics are covered such as fluids, belts are good, timing belt especially.Originally posted by evo90ex View Postmy 90ex i just bought has 245k on it. Im confident its still strong although it does have a light tapping sound from engine. It did pass smog and has no leaks( that i have seen). there is old oil around under the distributor. perhaps dizzy seal or something? Anyways, what do you all suggest i perform to the car to help it out like seals or something
If it passed emissions, thats a good sign. The tapping could just mean it needs a valve adjustment. But first and foremost, change out all the fluids w/ fresh stuff....and check all the little things you can.
That is most likely the distributor o-ring...and is a sign your other seals need to be replace...or it was missed...prolly means your t-belt is due/over due.
This is an interference engine btw.
I hope you know when the t-belt was done last. If not...do it. AND all the seals [crank, oil pump, cam, valve cover, upper spark plug seals, lower spark plug orings, rear main but you'd have to take out the tranny for it so maybe not], water pump, t-belt pulley and tensioners,
ALL your fluids, switch to synthetic after replacing the seals, including tranny fluid if manual, FLUSH don't just drain and fill if you have an auto...basically drain and fill 2-3x's to get the fluid red or almost red when it comes out...then do no more d&f's...
tighten the muffler bearings up, and fill the headlight fluid
sorry that was lame...
seriously also maybe an alignmt.?
wouldn't recommend a power build unless you rebuild the engine...but for long lasting just do the maint. items.__
__
Everything mentioned above, but also check your thermostat, replace your air filter, fuel filter, pcv valve, and a complete fluid flush, brake, power steering, coolant, transmission, & oil. Clean out your egr ports, and also have your fuel injectors cleaned & flow balanced. Due the most critical things first, and work on the list, while maintaining proper service intervals, and you will have a damn reliable car you can be proud of.
I just picked up a CB7 tonight with 261k. I'm going to take you guys' advice too.
1990 CB7 - Almost Done - Delta 272, SRI, 2.25 catback, Bisi intake manifold gasket, A6 intake double stacked, H22 plenum, AEM cam gear, F23a block, F22a head, Wiseco K20 pistons, DSM 450cc injectors
2004 Z33 - Brembo BBK, Nismo spoiler, Nismo lip, Nismo shift knob, AEM CAI
Besides the drive train I'd take a close look at CV boots, and the upper control arm and lower ball joints, make sure the brake lines look ok too safety being more important than just running. If you take it in for an alignment any decent shop, or a crappy one trying to oversell will take a look at these parts.
This is probably a thread jack and I'm sorry for doing so but:
How much is a usual valve adjustment for our CBs?
PROJECT: EIEN (Eternity, Endless) in progress...
"What's the point of a race?- Just means you're faster...that's all. If I have to race, it should be for something important..."
"What Is A Man Who Cannot Prosper and Better What He Owns?"
too bad your not in SoCal. Josue could do it for you for good price
imho, the following should be done after purchase of used car. reguardless of milage.
coolent change
transmission fluid change
oil change
all filters change
all belts change
valve adjustment
fuel tank flush
injector cleaner
alignment
tire balance
brake inspection
charging system check
suspension checkNo, I don't own a CB7, but I do own a F22A6 and a B16A trans. All going in a 90 integra sedanOriginally posted by Soichiro Honda, Honda Motor Company Ltd. FounderAction without philosophy is a lethal weapon; philosophy without action is worthless.
agree. and a detail clean
