a/c ?? more like heat
    i bought my car at the end of last summer and the ppl that i bought it from said the a/c does not blow cold ,, well i said ok, not reall a problem bein winter was right around the corner ..the heat is great, it was a warm winter in my cb7....but now the summer is comming back and i turn on the a/c 4 the first tyme it blew hot dust in my face lol ... but i still would like to know wat do i do to fix this problem help!!!!!!!!!!!!!!1
    First thing I'd do is have the freon checked by a local shop, it's relatively cheap. Make sure A/C compressor is in working order as well.
    If that's not the case, then I'd assume that you have a faulty temperature control unit.
    Good luck bro
      Make sure you button that looks like an arrow circling in the car is on and not the other one. (Don't know specific name for button)
      Next i would do, is go get your freon tested as dragtek1 said. Most problems come from not having freon in the line. If the nipple is still on the line, all you'll need is freon reinserted and you'll have an environmental fee, but it won't be that expensive.
      -Lance- (Formally known as H0ndaspyd3rLM)
      Originally posted by H22Artman
      if he still disagrees. well...... buy him a pink sweater and tell him to go buy some curtains.
      I posted a nude photo of myself on cd5tuner.com... it broke the site.
      Bought from: lo_dit, 924dr, Fatman88, 91project, noobcake, loud92cb7
      ٩(•̮̮̃•̃)۶
        Its called re-circulation, it pulls air from the passenger floor area instead of the vents in front of your windshield, and it should cool in either mode, recirc just blows the air at you harder, and if your vent is on feet, it loops to create colder vent temps when your ac is working.
        Check to make sure the temperature knob isn't broken, second check to see if the clutch on the compressor turns on when you press the a/c button or the rear defroster. Then I would check cylindrical level like device (you might have to clean it), its on the driver side, behind the windshield washer resevoir, its kinda in the fender in front of the wheel. If you have freon in your system you should see a bubble through the window, no bubble = no freon. You can also get a blacklight sensitive dye to add to your system when you retrofit 134a, which isn't harmful to the enviroment like r12, which your system was designed for. If after you recharge the system, it stops blowing cold, take a black light to all the a/c lines and the compressor and find the leak (most likely the compressor itself). Then replace/fix whatever the leak is coming from.
