cant get rear engine mount out
there are 3 bolts under the intake manifold to remove, one that goes through the bottom of the bracket into the tranny, the one on the strap. then the big one that goes through the mount. its easy! you dont need to remove the IM to do it.
Easiest way is first loosen the mount via the three bolts that hold it to the cross member. use long extensions and it will fit between the mount and the bracket to get to the front bold on it. once those bolts are out remove the bolt that goes through the bracket/mount. then remove the bolt that hold the strap to the tranny. thats all the topside bolts. then underneith remove the three bolts on the top of the bracket then the one on the bottom side. should be loose now. go back to the top and wiggle the bracket towards the back of the car. since you have the mount no longer attached to the crossmember everything shold slide backwards and the bracket will come off the engine. then just orient the two pieces while rotating the engine foreward a bit and everything will come out pretty easy.
member ride thread
DIVULGE MOTORSPORTS
Originally posted by fstacrd View PostUnbolt the actual mount from the rear cross member and move it back towards the firewall then rock the motor forward and remove the bracket.
member ride thread
DIVULGE MOTORSPORTS
