In the very near future I will be looking to lower my CB. I believe I have narrowed down to two options, Skunk2 struts and springs, or Tein Coilovers. Other than adjustability, is there any other advantage to the Teins, better performance, anything at all? I have had adjustables on my DSM's in the past and never touched them.... ever. Reading specs on both products they seem to be pretty equal as far as height. I would be interested in hearing from anyone with experience with one or the other or both. I'm assuming I will also be needing to purchase some sort of adjustable camber kit, is there a "best way" to go for this?
suspension setup help
There sure is a best way
It starts here: http://www.cb7tuner.com/vbb/showthread.php?t=470
I'd say in your case, go for the struts and springs if they're available considerably cheaper. You might also want to check out D2 or K-sport as they have really affordable coilovers.
A camberkit is probably necessary depending on how low you're going, but it's not gonna set you back much either.
so they got to be good quality stuff.
