how do i get the protecter plate off of the header i cant get the o2 senser out
headers
You may be able to rent an O2 sensor socket at your local auto parts store???? Or grab a 22mm open ended wrench or a pipe wrench. If it doesn't come off easy and you are able to start your car. Spray some WD-40 (PB-Blaster) on the O2 sensor and start your car. Let the exhaust and O2 sensor heat up a bit. And let the WD-40 start to smoke. Once it is nice and hot shut off the car. Be careful not to burn yourself and use the wrench again.
who dat do dat
