when should you change your spark plugs on average? i couldnt find a clear answer on the stickies
spark plugs
According to what I see in the service manual it says 24k miles or 24 months.
Here is a link to the online manual.
http://media.honda.co.uk/car/owner/m...al/400/4-4.pdf
Hope this helps.Where ever you go... Go Boldly
If your using basic NGK or Denso spark plugs I would say every 30K it never hurts to check them though. I have been using platnum NGK's changing every 50k with no problems. I change out the platnum plugs on chevrolets and fords that have 100K miles on them and they are a little worn but still work fine (I work for the government and they are cheap with fleet maitence)
Too rich can cause sludge and carbon buildup on the head, which can lead to damage... but it's not as dangerous as a lean condition.
And yeah, I've never had luck with Bosch. NGK and Denso are just fine. Don't be swayed by gimmicks... plugs aren't going to give you any more power. Get what's right for your engine, and it'll work properly.
depending on how the look like, plus are cheap as hell so why not doing them
__
