Popping/Clicking when turning left/right
    Yup I had the same problem and I replaced the Axles in my CB now I have to do the brakes
    This CB7-(Phebe) is the dawn of a new Era. Her new nickname is Super Supreme Fade
      Did it stop popping?
        Originally posted by JDMJohn View Post
        Yea, if I turn with the clutch pressed, it doesn't pop. I'll pull it up on the ramps tomorrow and check the axles, see if I can find anything without taking them off.
        you got your terminology mixed up.
        when your foot is depressing the clutch pedal you are DISENGAGING the clutch, hence no transfer of power from the motor to the transaxle.
        the reason your axles arent popping when your pedal is in is because there is no load from the motor. the axles are just turning freely without being turned by the engine.
        follow me?
        replace your axles, it should most definitely solve your problem
          Ah lol my bad. Okay then, I'll most definately get them replaced. Thanks to all for the help.
            bump for info.
            my cb, it does click/pop really when i turn left, and today it started to pop while i was goin str8.
            axle boots r worn 2 shit, i also shook the tie rods, and they were movin with ease.
            question is, which should i do 1st, axle or tie rod. ill have both ready to go on...
              Originally posted by F20A CB7 View Post
              bump for info.
              imo do tie rod ends first then the axles asap...i have seen tie rods break and that shit look scary...lolz..
                new axles are 70 each from advance.
                tie rods are 22, 31, 44, cheap, better, best
