i want to get drilled or slotted rotors for my 90 accord but i heard you have to get them pressed on is that true
question on rotors
soak it with PB Blaster if it doesn't work. Drill from the back and Break the bolt. (that what i did. I striped the head with impact wrench and had no choice)
The bolt only screw onto the rotor not the hub once you break the thread on the rotor it should be free. You might have to get a pry bar and pry the rotor off.
Pretty much a rachet witha really long handle.. I use a metal tube on the end of mine.Originally posted by justin'saccord View Postwhat is a breaker bar?
lolOriginally posted by XcluziveAZN View Post
Look what i did when all those steps failed ><
Replace bolts is like $2 ea from honda (majestichonda)
What, you tossed them in the fire pit for a night around the campfire???Originally posted by XcluziveAZN View Post
Only other way would be to heat them up red hot with an acetylene torch, let them cool, then hit them with the impact again. The heat expands them, then when they cool they basically break themselves loose from the threads. Some people say to hit them when they're red hot, but I disagree with that. Your chances of spinning the head off are better when it's still hot. I always let them cool down and have never had an issue.
Oh yea, Map gas torches from walmart won't work...
