I was installing an a/c retrofit kit on my 1990 accord and the fitting on the a/c line broke off. How should I go about fixing this? Any help would be apritiated
a/c fitting broke off
that sucks, you're SOL.
Order the pipe. I just bought a new one for my 92 for $113.00 Cdn
I suppose that you're going to need some FREON as well, no fitting to hold it in means it's gone. Off making a hole in the ozone.YEP. I AM Canadian.
1990 Accord EX 220,000 KM. Essentially stock with 15" alloys and chin spoiler added. K&N filter and Bosch plugs. ICE COLD A/C which I love!
1992 white EX 4 dr, 5 spd. (602,000 Kms and I JUST RETIRED IT. SO SAD!) DEC 9TH, 2005 - MAY 31, 2012. I added 229,000 kms to it. Great car!
here's a link showing all the parts in the A/C system. click hereOfficially "hilarious mad sarcastic"! Thanks CB74christ for the recognition of my work.
You can just grab another one from the junkyard. I assume you need the big pipe that runs in front of the rad with the low side fitting on it? It's not too hard to change and that last time I bought one, it was like $15 or something and that included the other half that bolts up to the compressor.
Make sure you grab the right hose. I've seen 2 different versions of the lines with the high side fitting near the passenger firewall and the other type with the fitting near the driver's side headlight.
BTW, I would highly recommend changing the o-rings. If you had no r12/r134a before, it's because it leaked out. past the old rings.
