Originally posted by cb7trancebeast
View Post
any hoo oil pan is pretty straight forward...cept you gotta drop the downpipe to get it out...not so fun as you now need gaskets for that. No biggy. I would do this with your next t-belt and get the oil pump re sealed...that way you don't waste those gaskets on JUST a small leak.
get that washer...soft one will seal better...crush one is good for one oc...at toyota we used metal ones...reused 'em like 3'x then replace.
could also be your oil pressure switch (RIGHT above the oil filter...drips behind and around the filter), mine would give a drop on the downpipe every now and then though.
More likely your oil pan gasket since it's all wet...but my drain plug also drips...nothing I worry about.
But any hoo when is your t-belt due?
__
