how do i get into my cb7?
    so i got my keys stolen and i to get into my car so i can start my swap. iv tried the hanger and i cant even get past the weather strip.? any ideas?
    H22 cb7:
    http://www.cb7tuner.com/vbb/showthread.php?t=133482
    cb9:
    http://www.cb7tuner.com/vbb/showthread.php?t=187076
    dd cb7:
    http://www.cb7tuner.com/vbb/showthread.php?t=203058
    if you got a ride
    you can take proof of purchase like your title to Honda and the VIN number and they'll cut you a new key.
    Yes my name is Dang, Don't use in vain
    1992 Honda Accord EX (Coupe/Bordeaux/Auto)
    1992 Honda Accord EX (Coupe/Bordeaux/H22A MT)
    2008 Honda Accord EXL (Coupe/SanMarino/6spd)
      You can fuck up your car easily doing this and I only know because I did it to my eclipse lol. Take the claw part of a hammer and put it in the seam of the door. Make damn sure you use a towel or something to pad it that way you DON'T scratch your car (like I did pretty badly being pissed at it) and then pry back ever so gently until the coat hanger makes it past the weather stripping. I'm sure you can figure out the rest from there. I had to have a locksmith cut me a new one before and it was 80 dollars. A friend of mine that used to run a wrecker service had a little bag that he would put in the door and then inflate it and it would push the door open enough to get the hanger or another tool through but for a one time use I would just be easy with the hammer and do it that way. You could always have a friend sit there with both hands pulling out on the door and that works too. It's a bitch sometimes but you can make it happen.
        Do you have any CB7 owning friends around? Very often, one CB7 key will open another car... I have yet to find one that does that, but I know it can be done.
          Take any paperwork you have with the VIN on it to a Honda dealer and the parts department will cut you a new key for 2 bucks or less. I have done this many times, you'll even get a "H" key if the dealer is good.
          1992 Accord Wagon (RETIRED)
            I used to could open my friends CB7 and even crank it up if I jiggled the key enough. But yea take your title to the Honda dealer and let them cut you key homie.
              I had no clue I could take my shit to Honda nd get one for that cheap. FUCKING 80 DOLLARS last time.
                damn Imma have to remember for the the next time I get my keys stuck..good lookin out guys
                  i lost my keys last tuesday and went to honda and got a new one but to get my registration i used a hanger and pulled my back window out a little and unlocked it try that
                  edit: honda didnt even have the cut for my fucking car because and they gave me some number and i went down the road and a shop cut it for like 15 dollars
                  to achieve a Fuck, you must first give a Fuck
                  Follow me on twitter @tru_whitetrash
                    use a flat head screwdriver wrapped in a towel. stick it in the upper right corner of the window.. careful not to chip the glass.. gently pry the window outward off of the weather stripping. use both screw drivers to work toward the front of the car. once you can get your fingers in just pull the window outward carefully as not to bend the regulator and wah-la stick your arm in and unlock it. once in slowly roll down the window slip it back into place in the weather stripping. go up and down a few times to make sure it is on track..
                      bat,brick,rock,and a crackheads head
                      okay get a tennis bal and drill a 3/8 hole in it put it up to the key hole and push the air will push the pins out and turn unlocking the door
                      http://www.metacafe.com/watch/410981...e_unlocks_car/
                      it works i have done it just not on a cb7 on a ford explorer
                        they test that in myth buster's and it prove false
                        -1992 CB7 EX w/H22 [sold 10/09]
                        -2005 Legacy GT limited [current]
                          shhhh i wanna see if he tries it lol
                          but no it didn't work but i did try it then i called pop a lock
                            yea. . . that doesnt work . . .
                            The Hatch < < - - - - - - - - - - - - - - My Cars - - - - - - - - - - - - - - - > > The Accord
                              Same method i used once when i locked my keys while at the mall . . except i used a stick i found . . the pressure of the window against the arm while trying to unlock is a bitch
                              Check Out My Work In Progess . . . . .
