engine swap need help
    i was wondering if the jdm b20b long block engine would fit in a 92 accord lx it is a f22 engine right now and would the f22 transmission bolt right on to the b20b
    With some custom engine mounts and a lot of money and time, yes, it could be possible.
    Just out of curiosity, why do you want a B-series? The H22A puts out more power stock, you have better torque, and it is a (relatively) simple swap (the mounts line up perfectly).
    1992 Prelude S w/swapped H22A
      Welcome to the forums
      why do you want B20? ......... 126 HP vs F22 140HP
      2.0 L vs 2.2L WHY WHY!!!
      why on earth would you want to down grade to smaller engine
      Get h22 or h23 if anything or stick to F22 and build it
      easier and cost less to put together
      check out Swap section to find out what fit and doesn't fit in our car
        Or click HERE!
        That list is mostly complete.
          H and F series engines are the only ones that won't require considerable fabrication and extensive wiring.
            that has been done but the only reason was just because
            it shares a lot of things with the d/b engines
              I am curious to why you would want to throw the b20b in your accord... but to try and answer your question, it would fit, but like someone already said, it would take some extensive modification (engine mounts, wiring, etc). Also the F22 transission will not fit the b series motor without somesort of adapter. If you were going F22/H22, there are several adapters out there to throw a b/d series trans onto an f22/h22, so maybe someone made an h/f tranny adapter for a b/d series.
              If you are really intersted in swapping another motor into your accord, for the amount of work it would take to swap the motor, you could probably throw in a v8.
                Are you planning to boost it.. What are your goals for that B20 if you do get in your CB?
