Gauge problem, temp. and fuel on maximum. help
    Hi
    Does anyone had this problem? My temperature gauge and fuel gauge goes on maximum position when ignition is on, sometimes they work ok but that is 1 of 100 times. Sensors are ok.
    Low fuel light is working ok, fuel sensor in tank is also ok.
    When I disconect sensors, gauges are still in max position.
    What should I do??
    Thanks
    No Turbo, No Fun.
    I'd check the electrical of the cluster, and make sure everything is getting the amount of power its supposed to at each point. If the reading is off, theres your problem.
    Worst case scenario cluster might have just ...
      I had the same problem with my old cluster. Turns out, the cluster was bad. I ended up getting a new one, never had the problem again
        my friend had a problem similar to yours, his cluster was fuked.
        if you remove it and start pushing on connectors it starts doing funky stuff. and we tried another one and it was fine, so it was the cluster.
        remember 90-91 was differnt clusters
        also they had the denso brand and the NS brand.
        Retro!
        Hater
          My is 92 Denso, i check it and everything is ok with cluster, i don't understand, how can it work sometimes if is bad?
          Is it posible that i got ground problems, broken wire somewhere??
          No Turbo, No Fun.
            Does anyone else know what can be a problem???
            No Turbo, No Fun.
              you calibration needles could have come out, just get a new cluster
                it can be fuked inside the board....thats about it.
                Retro!
                Hater
                  The board is ok 100%. But does the cluster from 91year accord can go on my 92year?? Are they the same??
                  Thanks
                  No Turbo, No Fun.
                    Just to let you know, problem was broken wire on cluster.
                    No Turbo, No Fun.
                      Dude that happened to me, it was a ground on the board, u couldn't even notice it, check ur grounds!!
                      Colombian CB7
                      http://www.cb7tuner.com/vbb/showthre...3A+1992+accord
