what can be blocked/deleted
    could someone give me a list of things that i can block off or delete that wont affect my car?
    like can i block off the air boost? or the EGR, IACV, FITV?
    like what all things can be removed deleted off the car (like the kinda stuff i have listed not things such as power steering and all that other obvious stuff)
    You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
    Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
    Don't remove IACV unless you don't DD the car...I't will bogg the engine down on idle when you use you Acessories.....But you can do...
    Detete P/S pump and A/C pump..Just run a smaller belt from the crank to the Alternator..
    EGR block off. (plate)
    Fast Idle block off. (plate)
    Air Boost block off. (plate)
    Oh and you can remove all the Cruze equipment....
    I have most of the listed above with no problems...but need to buy the plates still...
    Next is the ABS Delete for me...
    1990 Accord LX Sedan~Sold
    1993 Accord EX Sedan~Sold
    1995 Suzuki GSX-R 750~Totaled
      ok so i can remove those things and it will not hurt my car at all?
        ABS, CC, A/C, Power Steering, Interior.
          No it wont hurt anything at all and you can still drive from here to Cali if you please...lol
            http://www.cb7tuner.com/vbb/showthread.php?t=137285
            ok so all those block offs are alright for me to block off on a DD?
              you can also remove the charcoal canister and evap purge solenoid.
                ok im just looking to remove all this stuff to unclutter my engine bay alittle.. cause i cant do a wire tuck cause i have no idea what to do even after reading the diy
                  could i make my own block off plates? i got the alluminum laying around
                    Oh yeah you can make your own no problem.
                    You can also use some aluminum flashing or a soda pop container, real simple.
                    Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
                      i dont wanna thread jack but, why do so many ppl on here remove the cruise control? does it not work and you wanna remove some weight or what?
                      The Hatch < < - - - - - - - - - - - - - - My Cars - - - - - - - - - - - - - - - > > The Accord
                        Mine doesnt work, But it is on my removal list regardless of it working or not. You couldnt gain atmost 5pds of weight loss removing the cc. Just my .02!!
                          I rarely used it, it looked ugly in the engine bay, and took up too much room.
                            You can blank off the IACV if you don't mind the idle speed dropping with auxilliary load (which causes vibration), but this problem can be lessened by raising the base idle speed to a point that when the idle drops (with AC use etc) the idle doesn't drop so heavily into the vibration red zone.
                            Blanking off the IACV is only useful for manual gearbox cars, and makes gear shifting much more pleasant, faster, more predictable, more accurate and thus smoother. This is because the IACV momentarily permits significant airflow to bypass the throttle plate after the throttle plate has been closed, causing the rpm to momentarily 'hang' at higher rpm, and to then drop more slowly (than would be the case without the IACV functioning).
                            I believe this is an emmisions control measure, but it messes with the 'drivability' of the car. Try it, if you don't like it then remove the blanking plate.
                            Regards from Oz,
                            John.
                              Yes, it's easy, just make sure there are no air leaks.
                              Don't disable the IACV by unplugging it, this causes a CEL, and also causes a problem with injector cut out on the overun and very light throttle that makes the engine behave in a harsh and unpleasant manner (try it, you'll see what I mean).
                              Regards from Oz,
                              John.
