So i was reading this thing on ebay where it eleminates the coolent lines into your intake, makeing your cold air intake a true cold air intake. Because it doesnt heat up the air going into your moter it says its a 4 to 8 hp gain and it shows dinos. Can anyone tell me if this works? im tempted to try it give me your opinions on the issue thx
4 to 8hp gain?
^^ agreed 4-8whp is highly unlikely.
Maybe 0.5 to 1 at the most. Which isn't even noticeable.
My 5.7 LS1 Holden Ute
if it dose make the air going into the moter not as hot then there would be some type of an increase in hp i think im gunna try it just to see but i dont have an dino so i cant prove any increse http://cgi.ebay.com/ebaymotors/90-07...Q5fAccessories
Originally posted by speedofsound760 View Postif it dose make the air going into the moter not as hot then there would be some type of an increase in hp i think im gunna try it just to see but i dont have an dino so i cant prove any increseRegards from Oz,
John.
With a carburretored engine that uses a heated inlet manifold where a large % of the manifold wall is exposed to a substantial amount of heated coolant that is constantly replenished, then there would significant gains to be had from eliminating coolant flow...
Having said that, blocking or removing those hoses won't hurt, so long as you don't live in very cold climate in which case you risk icing up the throttle body, IACV, and / or FITV.Last edited by johnl; 07-16-2009, 07:39 AM.Regards from Oz,
John.
hey i never said i was gunna buy it guys i was gunna by pass it. i have hose that will fit it. it cant hurt if it works and if it doesnt add horsepower then its not hard to put back to stock. its one of those things that could or could not work like the whole dampner belt deleat it could make a diff or not. but im willing to try every little bit adds up to alot in the end but hey im just trying to do with out a turbo set up. ive done a few and there getting boring i want to build a na moter no bs old school style plus you get more respect when you dont just go turbo. hell when i max out i might just supercharge it for the hell of it because i havent seen a cb7 supercharged humm........
If you want to go N/A, take a look at Cisco's CB's "HondaFan81"
White Project F22 non-VTEC SOHC Full Street
Red Project F22 non-VTEC SOHC "Mild"
All Motor Build General Information Thread
Originally posted by speedofsound760 View Postit cant hurt if it works and if it doesnt add horsepower then its not hard to put back to stock.
Originally posted by speedofsound760 View Postplus you get more respect when you dont just go turbo. hell when i max out i might just supercharge it for the hell of it
You should build an engine according to the manner that best suits your purposes, not 'just to be different'...Regards from Oz,
John.
