well i jus did a wire tuck on my cb7. and tried starting it up.. first the fuel pump was'nt kicking in.. but i got it working.. now i'm getting no spark.. does anyone know wat it could be?
no spark.. need help
Main relay does the fuel pump.
Igniter, coil, battery cables, grounds, distributor, cap, rotor, plug wires, plugs, ECU. Those things are necessary for spark.
Since you did a wire tuck, it's going to be very hard for us to do much online troubleshooting for you. Wire tucks look great, but they cause a serious mess when something goes wrong!
Check and replace all the things I have listed. If it still doesn't work, start tracing wires and look for a problem.
Thermostat ground?Originally posted by str8jdmswap View Postoo. thanks guys.. but it was a ground i missed in the wireing harness on the motor.... just connectedthe ground.. and it started right up...
My 5.7 LS1 Holden Ute
