If I were to install a cold air intake and performance exhaust manifold and muffler (I believe these are the three easiest performance modifications to make to this car - correct me if I'm wrong), should I make an adjustment to the cars ECU or replace the ECU in the process since readings may be off once air flow through the engine has been changed?
Adjust / Replace ECU necessary after Mods?
just reset it so it recognizes the changes made.Originally posted by jkrolikowski View PostIf I were to install a cold air intake and performance exhaust manifold and muffler (I believe these are the three easiest performance modifications to make to this car - correct me if I'm wrong), should I make an adjustment to the cars ECU or replace the ECU in the process since readings may be off once air flow through the engine has been changed?
Bought from: Bisimoto
, FuncOvrForm
, HondaGuy1212
, wed3k
, Konigstiger
, 1st2run
, BillKisme
, k-mart
, benjerman112
You can get yourself a different ecu and have it tuned. Tuning is one of the best mods you can do, especially with a few added bolt-on's. It isn't necessary though.Originally posted by jkrolikowski View PostIf I were to install a cold air intake and performance exhaust manifold and muffler (I believe these are the three easiest performance modifications to make to this car - correct me if I'm wrong), should I make an adjustment to the cars ECU or replace the ECU in the process since readings may be off once air flow through the engine has been changed?
I'm assuming you have never tuned a car, so in that case you can either learn how to do it, or you can take it to a tuner. If you don't mind having your motor maybe blow up then you can try learning how to tune, but if you care about the motor, then I would suggest taking it to a tuner.Originally posted by Zmatt View PostWhere do you get your ecu tuned? Is it something you can do with a laptop or do you have to take it to a pro?
There are a few member's on here that chip and tune ecu's. Jose a.k.a D112crzy is one, there are a few others, but I know Jose has a thread in the "members' shop" forum. I would talk to him if you are looking to tune your carLast edited by mozzandherb; 08-04-2009, 12:52 PM.
