does anyone know how to fix the tempeture gauge mine isnt working and i would definitly like to have one
engine temp
Your temp sensor might be bad. the sensor the is responsible for the readings on your dash is located under the Dizzy to the extreme right and it is screwed into the block. it also has 1 wire attached to it (someone correct me if im wrong). . make sure that its not loose. Once you have visually and physically inspected the sensor and its still not giving any raedings, replace it.
This is good information. I replaced my ECT sensor last week along with the thermostat. I still have that same issue where the temp gauge shoot up as soon as I start the car. Any IdeasOriginally posted by plee3 View PostYour temp sensor might be bad. the sensor the is responsible for the readings on your dash is located under the Dizzy to the extreme right and it is screwed into the block. it also has 1 wire attached to it (someone correct me if im wrong). . make sure that its not loose. Once you have visually and physically inspected the sensor and its still not giving any raedings, replace it.
