major headache
    major headache
    hey guys im in the middle of my 5 speed swap. i have all the pedels in and shifter. new mounts to. my problem is i have most everything done but one of the flex plate bolts stripped. the head of the bolt. all i need to do is get that bolt out and i can bolt up my fidanza flywheel. im so lost on what to do. the last thing i want to do is buy a new crank.
    thanks in advance
    Ean
    this EXACT thing happened to me and adam (mndude07) when we were swapping his car over to 5-speed. use a sharp chisel and a hammer to hit it counter-clockwise. the chisel will bite into the bolt and spin it around. we tried a LOT of fixes for this, but this is the only thing that really worked,
      Yup, its true.
        i dont understand were to hit the bolt under the head between the bolt and flexplate or on the side of the head
          On the side of the head of the bolt
          My 5.7 LS1 Holden Ute
            Ive welded another piece of metal to it B4 and used that to turn it.
              That's probably a better idea than hitting it.
              Another way is to file down the sides to a flat surface and use vise grips to turn it.
              Do you have the 5 speed conversion mounts (not mounts from a 5 speed, but the ESP conversion mounts)? Or have you welded in the 5 speed transmission bracket? You need to do one or the other.
                This works well. For some stuck bolts, I'll take a nut and weld inside of it (where the bolt would go) to attach it to the bolt head, then use my wrench on the nut. Works pretty damned good.
