whatt is wronggg?? =/
    ok i drove to work just fine.... parked it... on my first break i went to check my fluids (like i always do) went to turn on and nothing i disconnected the negitive put it back on and i saw that my dome light came on... hmm i was thinking that it was just a bad connection so i went to turn it on.. my radio was on dome light was on electronics was just fine then i went to turn it on and everything just shut off and no crank or nothing just blank..... i went to the negitive again and disconnected it and connected it again and again..... dome lights door lights everything was working but when i go to start it everything would shut off.. so finaly i disconnected both prongs negitive and positve poked arounddd made sure everything was good. put both prongs back on and IT STARTED! i was like wtf? i got no jump nothing so my battery wasnt dead.
    possible things that it could be according to friends and brothers
    1.dead battery
    2.starter
    3.loose battery cables
    idk what this could beeee! ughh i just want to be able to drive to work and back =/
    any input would really help
    loose positive cable?
      Yep, sounds like your cables weren't making a good enough connection. Take em off, clean the terminals and the posts.
        really?? what are some type of symptomes of the starter going bad? would like all of the electronics turn off when you go to crank? btw thanx for the input =]
          Sounds like a bad/dirty connection. The earth cable is common for causing this fault on Cb's.
          My 5.7 LS1 Holden Ute
            earth cable?
              Originally posted by jdmaccord5000 View Post
              earth cable?
              Earth, Negative, Ground. All the same thing
                ohk cool =] thanx for the input guys huge help
                  When you were trying to start your car, did it make a clicking noise, out at, or near the battery?
                    yea it actualy did just a little click but no crank. what can that be?
                      their right just bad connection, happened to a friend of mine the other day, everything worked fine in the vehicle electronics wise, but the connection was just bad enough not to give enough current to the starter. loose corroded cable.
                        loose or dirty cables...check all the wires..ground..starter and power
                          *click* and everything on the dash turned off, right?
                          Loose or dirty battery cables, as it has been said over and over and OVER again in this thread.
                          A bad starter has nothing to do with the rest of the electrical performance of the car. A bad starter will either not work at all, or, more commonly, it will whir as the motor spins but doesn't catch stripped gears.
                          This problem is NOT your starter.
                            alright cool =] thanx guys for all the input
