About to pull my f22,quick question
    i read the f22 removal in the swap section and it says to remove the axle but in the editors note it says you do not have to...
    so i geuss my questions is...
    i have everything unhooked except the drive shafts...
    can i just hook the lift up and pull the motor up out and the drive shafts will pull themselves out or what?
    much appreciated,
    bucky
    You don't have to like what he did, but I would hope that you can appreciate the time, money and love that went in to the build. If you can't, you're not really an enthusiast, just another dumb kid with a car.-visualpoet
    Money and Knowledge are never in the same sentence, because people with Money think they know it all, but people with knowledge, know better.-ragingasian
    I believe that's the idea, although I've never actually done it without just removing the axles.
    If you do just lift the engine with the axles in the half shaft and transaxle, watch to make sure the axles don't hit the shock assembly fork.
      Youll probally rip the boots apart....
      You can seperate them at the tranny with like a crowbar as you lift.
      Some people dont want to take the axle nuts off, I know why lol
      Your man for wiring solutions!
      CB7Man's Coupe H22 Swap
      CB7Man's Sedan Resurrected From The Dead
        yeh after seeing all the problems people have getting them off i dont want to.. so as i lift up up just pull them off then finish lifting out?
          Dont you have to at least remove the drivers side axle (if you have a manual) to remove the engine because of the secondary shaft that is on the drivers side?
            ooh by the way it is an auto if that makes any difference to the situation
              ive tried that method and it doesnt work. the axle shafts just hit the suspension fork. what you can do is disconnect the axles from the tranny/ halfshaft, disconnect the lower ball joint and just swing them out of the way.
              i have to take them all the way out because i need room to move the car back and forth. gotta make use with what i have.
                how am i supposed to disconnect them from the tranny without taking the out of the axle first
                  disconnect the lower ball joint and the entire spindle will come out of the lower control arm and swing but will pivot on the tie rod that is still connected.
                    ok thanks
                      Just pull the axles. It's not difficult. If you break something, you're going to be making a lot more work (and expense) for yourself!
                        Word of Experience / Word of Caution
                        I have done it both ways. If this is your first rodeo, leaving the CV Axles in is asking for trouble.
                        1997 Honda Accord EX-V6:
                        Originally posted by James Matteu
                        You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
                          I..Honestly.. can not get that stuff of to get the shafts off.... i tried the whole control arm thing without taking the axles off.. did not work. so i put the bolts all back on.. and tried to get the axle nut off but i dont have a 36mm socket.. and my parents took the car on vacation so i have no way to get to the store to get a 36mm socket..
                          this is absolutly horrible i need to get the swap done i start school next monday
                            Is there anyone that can give you a ride to the store? Taking the axles out, which means pulling the axle nut and popping the ball joints, is really the only easy way. You'll be screwed if you damage the axles... you'll then have to take them out AND replace them!
                              well i called my buddy he works at cosco tire or however its spelled he said he might be able to bring home a 36mm and the impact gun for it since its a 1'' drive or something like that..
                              man my whole rebuild/ teardown was all so smooth and fun.. now its like i hit a brick wall
