I have a 1993 se parts car from my brother. I would like to pull the rear disc off of it will i need to change e brake cable and the proportioning valve. Next the header on it. It looks like a better flowing then the old cast one piece i have on my dx. The header is on the a6. Thanks if anyone can help me out with this.
have some ?
i think his question is stated.Originally posted by blueboy92 View PostI have a 1993 se parts car from my brother. I would like to pull the rear disc off of it will i need to change e brake cable and the proportioning valve. Next the header on it. It looks like a better flowing then the old cast one piece i have on my dx. The header is on the a6. Thanks if anyone can help me out with this.
he did ask a question...he just didn't put a question mark (?)Originally posted by visualpoet View Post1 post since 2004? And, uh, you failed to ask any questions. Your post is a collection of statements. What do you need help with?
to answer his question: yes, you have to use the e brake cables that are on the rear disc set-up. the cables from drums and disc are different. as far as the proportioning valve, i have a lx sedan, and i did not swap over my pro. valve, just rear disc set-up w/ cables and trailing arms... i dont have any problems what-so-ever...
most peeps on this forum w/ prob. bash me...but whatevers...my car stops fine...so, i'm gonna tell you to change over the proportiong valve...cause i dont wanna be bashed for giving you "bad info"
SO CHANGE THE PROPORTIONING VALVE AS WELL...Last edited by PhatAccord; 08-25-2009, 06:47 PM.
