in the morning the cb takes like three trys to start and the sport light flash. after drivin a lil and turn the car off and on the light stops and everything is normal.y is that
starting problems
Re-phrase your "ebonic" sentences into a normal language to where it can be interpreted and then maybe you will receive an answer.Originally posted by da1prettyboii View Postin the morning the cb takes like three trys to start and the sport light flash. after drivin a lil and turn the car off and on the light stops and everything is normal.y is that
First off, I cant tell what year is your car. Your sig looks like its a 92-93 so I will just go what you said that you have a "Sports Light" in your car. (90-91 has a sport light, 92-93 has a D4 light that flashes) I would check what code comes up on the TCU. There is a proceedure some where around this fourm. Try a search for it. As far as your starting problem IMO, you might want to check the main relay under your dash. That might be the probable cause of your starting situation.
i couldnt make much sense out of the question repost plz
