ok, i bought my car a week ago, its a 1990 accord lx, 197,000 miles for $500 bucks, engine is great xcept for the relay not wrking sometimes, gna fix that soon. but my big concern is the tranny doesnt seem to shift out of 1st unless i go way up to 4000 rpm and let off the gas, then it engages 2nd 3rd and 4th but if u press the gass hard like to pass someone it just revs up and wen it comes back dwn it goes back to wtver gear it was in , sport shift does not wrk, cant manualy go to 2nd, i seen a lot of diff explinations for this, like the solenoids, so i got new ones (the upper and lower ), i also replaced the tcu/tcm just in case, i get no codes,tried that, ressetting, chnging fluid, still no thing.I heard it could be a stuck valve in the valve body, i dunno wut else do i chk for??
Tranny wont shift!!!
check your tranny fluid level. I know you said you changed fluid, but did you put enough in?Last edited by wherm; 09-09-2009, 07:29 PM.
yea ill give u a link to a good page, i havent tried the vss though, ddnt think i needed too since the speedo wrks, someone told me to chk the throtle pressure cable that connects from the throtle body to the tranny and make sure that it moves freely on the tranny. and to flush the tranny.gna try this tmrw.lemme kknw if the site helped out.Originally posted by AD5OS View PostGot a similar problem. Did you try the VSS too?
Is there a way to test valves and solinoids?
http://techauto.awardspace.com/transmission.html ( to test solenoids)
whoa..Your problem is the same as mine but slightly different,mine will not change gear until it is rev to 4k rpm but it changes to the 3rd gear,i cant figure out wat is causing dis and how do i fix it..Originally posted by bendeezy82 View Postok, i bought my car a week ago, its a 1990 accord lx, 197,000 miles for $500 bucks, engine is great xcept for the relay not wrking sometimes, gna fix that soon. but my big concern is the tranny doesnt seem to shift out of 1st unless i go way up to 4000 rpm and let off the gas, then it engages 2nd 3rd and 4th but if u press the gass hard like to pass someone it just revs up and wen it comes back dwn it goes back to wtver gear it was in , sport shift does not wrk, cant manualy go to 2nd, i seen a lot of diff explinations for this, like the solenoids, so i got new ones (the upper and lower ), i also replaced the tcu/tcm just in case, i get no codes,tried that, ressetting, chnging fluid, still no thing.I heard it could be a stuck valve in the valve body, i dunno wut else do i chk for??
one of my boys was having a similar problem ,turned out to be a bad TCU .
replaced it and everything was fine.
but it could be few things( bad tranny solenoid,bad TCU,or tranny filter is clogged up)
78% of the times when we rebuilt a tranny at the shop,it's always end up being a clogged up filter.
i'd say see if you can borrow a TCU from a friend and try it on .
just to eliminate that possibility before doing anything else
I replaced the tcu and tried another one, i changed the oil 3 times alrdy and changed all sensors on the tranny,i think its gna be a stuck valve in the valve body, or possible dirty filter.Originally posted by MR.PHIL View Postone of my boys was having a similar problem ,turned out to be a bad TCU .
