air booster valve
    air booster valve
    A few weeks ago I had started a thread about a strange whining noise coming from my engine bay that I couldn't pin point. I removed my abs control unit because the abs light was annoying me and the noise stopped. I thought that the noise must have been somehow connected to the abs system, but a week or so later that noise came back. I was able to track it down and it is coming from the air booster valve. I have read that this can be removed with no ill effects, but I can not find any info around the forum on how to go about doing so. Is it better to remove it all together or replace the part? If anyone has removed/replaced one before, could you give me a quick run down? Thanks
    from what i understand, the air boost valve is for extra vacuum during cold start up...the jdm motors did not come w/ them...when i did my swap, it didnt have one, it came w/ a block off plate. so when i smogged/reff'd my car, i swapped my block off plate w/ a friend's air boost valve...all it is, is 2 bolts, and a vacuum line that connects to the throttle...
    if you have a whining noise from it, why not try and fix it? if i remember correctly, it has 2 o-rings under the valve. check them to make sure that they aren't worn and leaking...they aren't that expensive, and you can also pull one from a junkyard as well
      Sounds like a vacuum leak your describing, How did exactly you narrow it it down to the ABV?
      You don't need the abv as myself and many other members here have disconnected it.
      My 5.7 LS1 Holden Ute
        I tracked it down by quickly poping the hood when it would make that sound and I narrowed it down to the center-rear of the engine bay. It would usually quiet down really fast so i couldnt pin point it exactly, until yesterday. I lasted a little longer and I was able to track it down to the ABV by getting down close with a good ear and verifying it with the old screw driver to the ear trick.
        I think I'm going to try and fix it just so I can have something to tinker with. thanks for the info, guys!
